Wadula is completely right, I just want to give some depth to the explanation...
In ideal, the wheel shouldn't speen at all to get the maximum possible acceleration, cause when they start to slip the friction force which pushes your car forward actually goes down !
So don't warry about it much. To get the wheels spined the torque that is applied to your wheels by driveline should exceed the maximum friction force between your tires and pavement * the radius of your wheels, so you get the maximum torque at the 1-st gear,
and high revving your engine and dropping the clutch means that you produce high torque at your engine + transferring the angular momentum of the engine+flywheel in a short time to the drivelin and wheels, which gives you a high torque pick (the torque is equal to the speed of the angular momentum change)... You cannot high rev the eingine and drop the clutch on your car since it is automatic, so you need to either decrease the radious of yur wheels, i lower the friction force between your tires and the pavment(which happens on wet road), or increase the torque produced by your engine, since the max torque of your engine only is not hogh enough to spin the wheels(get a v8, no wait get better a v12 , or W16
Mine is 87 325e, and to get a wheelspin on a very good set of tires on 14" rims I need to get to about 3000 rpm and drop the clutch. On my previous set I could rev lower, and the sh*t was spining in the rain all the time so I had to take of on 3-rd gear..
Hope this helps you...
