cprogrammer said:
"catch area". So, I let the clutch out fast till I heard it grab, at which point I gave it gas, and then just completely let go of the clutch. This worked once, but the rest of the times it just stalled. Is this something you just need practice on? I can't while in traffic take my time on the clutch to prevent stalling so I'm trying to learn how to do it quicker in parking lots.
give more gas when you are attempting what you describe above. maybe rpm around 2k or so. and keep it there while anticipating the light to change. and slowly disengage the clutch. you may rub the clutch while it engages, but you won't stall and you could prolly go fast enough. (as you get better you get a better feel for the clutch, so you should be able to take less time in that process w/out stalling.)
but remember this: if your clutch release is slow in the subsquent shifts, that'll slow you down a lot, even w/ a good first gear start. as you are just rolling in neurtal while you shift and engage the gear, which may take closer to a second. and you prolly shift to 3rd, 4th or even 5 gear before getting upto 45-50 mph, that'll slow down traffic more than your slower start. so to minimize that rev higher and you can prolly go upto 45-50 w/out much strain on the third gear, then skip the 4th and pop it into 5th, or whatever gear you use to coast at the given speed.
also, if you are wearly of shifting too much, and are on a flat road or down hill (ie not going uphill) you can prolly start off in the second gear. first gear is usually really low, and really good for the go fast situations, but if you plan on acceling slowly, you maybe able to skip that gear.) something to think about in your parking lot sessions
