Its not necessary to remove all the gas. But the idea it that you need to get the RPMs down so you dont jerk your car around. You would let off the gas, clutch in, change gear, clutch out with a bit of gas to keep the engine rev up, you will notice how you can do it smoother and quicker.
when you are shifting up to that next gear, you want to have your RPM real close to what might be expected for the gear change at that speed you are traveling at. Thats why like the guys say, get used to your clutch release point, but also learn your gas pedal.
you could put a load of gas on while changing gears and release the clutch slowly and make it real smooth, but that will only wear your clutch right out because those plates (much like the brake pad and rotors at your wheels) create a lot of friction. So just practice smooth quick shifts with rev matching.
Once you get all that down, you can move to the next lesson, really only used when down shifting. In your standard tranny, you have what are called synchronizer bearings which slip when engaging gears so the tranny can more closely match the speed of the input to match gears, thus called the synchroizer bearings.
When down shifting, you have to rev up the engine and release the clutch so the wheels end up engaged to the engine at the right speed to keep it smooth, but you will find its hard to do because the tranny has to catch up in that process. this will make down shifting seem flawless!!
1. clutch in
2. shifter to neutral
3. clutch out
4. blip throttle to speed up input shaft and synchronizers
5. clutch in
6. shifter to lower gear
7. rev match with throttle to anticipated RPM
8. clutch out
This might seem like it takes too long, but once good at it, it takes no longer than a regular shift. Once really good at it, you can skip parts 1 and 3 just by taking the weight off the transmission and pulling the gear at the at the right moment.
You can read up a little more here:
http://www.strictlyeta.net/doubleclutch.html
Happy shifting!
( i cant wait, im swaping auto to standard in my e30
![Big Grin [:D] [:D]](/images/smilies/biggrin.png)
