transmission fluid and radio clock adjustment
topless01
12
san diego,ca
Hi All,
I need help adjust the clock in the radio display of my 2001 330ci convertible and wonder how to check and change out the transmission fluid ? Thank you in advance for all your help.
topless01.
14
ct
i looked it up in the operators manual and when you change the dash clock the radio changes with it. i think i used the right knob in the guage cluster and turned it i will have to check for ya later sorry i 'm not much help i'm a new bmw owner and trying to learn myself!
topless01
12
san diego,ca
i did follow the owner's manual instruction in page 84 but didn't work. not sure the knob is malfunction or i need the radio's manual to adjust the radio's clock. thank you for your help and take time to reply my message.
14
ct
he i will get back to you more tomm abotu this i know the know onthe right is to ajust the clock on the radio and the gauges. I think i turned the knob and it changed it bu ti will check on it tomm i've only done it once. The car i have is a 2000 323 so i should be the same ttyt
14
ct
ok here we go this time in english j/k
to set ahead: turn the right button towards the right.
To set back: turn the right button towards the left
the adjustment speed will increase the longer you continue to hold the button.
(to change the 12hour mode to the 24hr mode press the knob)
say u r in the car without the key in the ignition, u can press the left button and it will tell u the time for a few seconds! hope i was of help with the clock, my car could be dif from yours hope it works for ya!
o and the tranny is a long story to check it. I read a lil last night about it. you have to have the car elevated level, get the transmission to a certain temp, might be running temp(i could look it up if ya want) then u have to turn the ac on to boost idol( should boost pressure in the tranny)then u have to apply brake put the tranny through all the gears.this fills all the passages in the tranny with fluid, then u open a plug on the side of the case and if it come out the level is ok, if nothign comes out it needs to be topped off withthe same fluid. there are many dif types of fluid, u need to use the same one. i think they are color codes too! i have the torque spec on that plug too idk if your going to try it but thats a breif description for ya if u wanted to know whats involved. if u want i can email ya it step by step if you at going to tackle this job let me know hope it was clear and helpful ttyl [headbang]
topless01
12
san diego,ca
thank for your help wildjon. it didn't work on mine. maybe the knob is bad. about the transmission fluid, i took it down the dealership and they told me not to worry about it. its lifetime transmission fluid ? i did read a little about the bimmer tranny in the forum and kinda a confused. i want it to be well maintenance like my engine oil. i will check it out with another bimmer service shop to see what they say. do you know any and san diego area ?
topless01
12
san diego,ca
hi wildjon, i've got it adjusted. i didn't realized i must select the clock from the turn signal level before i can change it. it ok now. do you know what's little ATF container with the lever in it ? it's next to the oil filter container ? Is it Automatic Transmission Fluid ?
14
ct
not sure what your talkign about r u asking what a light means on your dash i will look it up if so? i only have mad my car a couple months but i bought the bentley service manual its great for 83 bucks the clock i looked up in owners manual let me know what u wanted about the atf and i 'll look it up for ya! i live in CT/NY so i'm just getting used to this bmw stuff I went form old muscle cars from the 50's and 60's to newer bmw's what a change but i like it! i find it a fun challenge what kind aof car do ya have again! glad u got the clock right! ttyl
topless01
12
san diego,ca
the ATF container i'm talking about is in the engine compartment. not in the dash board or a light. if you open the hood you will see it, its in between the oil filter container and the radiator. i think its the transmission fluid but not quite sure.
i just bought this 2001 330ci convertible last month. never owned and German car before. i really like it's handling and the topless since san diego and so nice year around. i also owned a suv.
14
ct
hello what i think your talking about is for the power steering! atf is also used in the power steering. the transmission does not have its own bottle. to put tranny fluid in, u have to jack the car up. o and they used to say the tranny fluid was life time, but they changed it in 2002. they said change it at 100,000 miles but put new lifetime fluid in it, hope i was of help!
