I have a 528i 1997 and the radio goes in and out. I am trying to find out what to do rather than paying an "arm and leg" to go to the dealership. Any advice?\
By in and out do you mean the reception, or the electric aerial? If it is reception check the aerial connections behind the radio and then at the aerial itself. If it is the aerial it may be a loose earth or loose power connection.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
