Bryan330i said:
I figured it out once for my 325i. The redline on that car is 7000 rpm with the chip.
[brahtw8]
So I have a question. To say that I am not a mechanic type person with that level of knowledge would be a big understatement. But how can you get such a large increase in red line from a chip? I thought that you would need to make engine modifications because the red line was the physical max the engine could withstand. Mine is 6800 a little more than the standard 330i, and I thought that was because of physical engine differences such as the cam and so on. Could I chip mine and then run the engine past the 6800 red line? Without damaging the engine? Just curious.
I don't know if Dinan or others offer a software upgrade for the 330i PP. They probably will in the future, but it may or may not include an increase in the rev limiter. It would eliminate the top speed governor.
With no fuel cut-off, you could rev your engine until it blew up. At what rpm that happens depends on the kind of engine and the shape its in. If I were to hazard a guess, I would expect my 325i would blow up at 8500 rpm, but start to do damage at 7300-7500 or so. (Pure speculation on my part).
On a BMW, your greatest chance of doing that is on a downshift, as the transmission will let you into a lower gear without regard to what speed you are going. The typical 'money shift' is from 5th to 2nd, and will blow your engine if you shift into 2nd by mistake when you are doing 80 mph (in my car 2nd is good for about 63 mph at 7000 rpm).
The factory settings can be somewhat conservative. They make certain compromises in the name of fuel economy, emissions, longevity, etc. I would expect the 330i PP to be in a slightly higher state of tune from the factory, with less room for improvement, than a standard 330i.
1995 and older BMWs came with OBD I emissions and have much more flexibility in the aftermarket as a result. Since OBD II came out, software upgrades (instead of chips) don't provide the kind of gains that chips used to (for the most part, with some notable exceptions, turbocharged cars for one).
