The 318i I'm looking at has 110 k miles on the engine/car. Does anything need to be done to this car? Like timing belt, water pump etc? The exterior and interior are in perfect shape.
So if it doesn't make noise the timing chain is alright? How expensive would it run to replace the timing chain? The chain should be replaced every 60-100k right? Any other expensive repairs can I expect to perform? Thanks for the help.
timing chains can last more than 200k. My 91 318is had over 164k on it when I sold her and still running the original timing componets. Has the car had the scheduled BMW maintainence done?
I don't think so. Besides oil changes. The guy bought it about a year and a half ago at a dealership and they usually don't maintain any sort of records on a car. I'm sure things were done to it but there's no way of knowing. The interior is in perfect shape and so it the outside. I can check the tranny fluid and ratiator fluid and etc? Anything else that is crucial to check? Thanks
I would have all the fluids changed, radiator coolant, differential, transmission, power steering, brake, and engine oil. If they all check out, no burnt odors, no signs of metal shavings leave it at that.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
