Help,
The radio has no sound, I have channels and every thing else but no sound ? ?
The CD works and the Tape deck too, lots of sound, any thoughts on what to look for? The audio system is 100% stock.
So you have sound from the CD and the Tape but no sound in radio mode? One of two possiblities:
1 - A failure internal to the radio in the radio receiver section.
2 - A failure external to the radio in the antenna circuit. Your car probably has an antenna amplifier near the rear windshield. In the 3 series it is in the pillar next to the rear window behind the trim. I don't know about your car. The amplifier could have failed, or just lost power. Either way, you would likely get no reception.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
