Hi Everyone
I am a complete novice
Nevertheless, I wonder if you might be able to help me out. I have a 1990 518i manual with 175,000 miles on the clock, that has run OK for the two or so years I've had it.
Last week, however, the engine stalled as I accelerated into second on a slight hill. I couldn't get it started again so rolled backwards down the hill and tried to bump it but to no avail. I phoned the roadside assistance people, and when they arrived it started OK but the idle was erratic, going from 1000 to about 4000 revs and then cutting out. This simply righted itslef after a while and the car drove as normal.
I thought there might be a fuel starvation kind of problem, so added injector cleaner to the tank and noticed an almost immediate improvement in engine performance, although the idle speed was moving between about 500 and 1000 revs. A couple of days later, I had the fuel, air and engine oil filters changed. I had the sparks done about three months ago.
The car was going fine for about a week until, coming home from work tonight, the engine just died, once again accelerating into second. This time it was not possible to restart at first, although at the third attempt the engine fired with revs shooting up (to about 5000) and down and finally cutting out. I got the tow truck to take me and the car home and it won't start at all now.
I phoned a couple of mechanics I know, who made noises about the airflow meter or maybe coil. None seemed to think the injectors a likely source of trouble and scorned my feeble attempts to clean it. One even hinted darkly at possible ECU failure.......
Now, I am no expert at all - and will obviously not be trying to effect any but the most rudimentary repairs myself. But the thing is, I live in Spain and honest mechanics are even thinner on the ground here than in other parts of Europe. So what I'm after are a few pointers to sort of head me in the right direction.
Any help gratefully received.
Richard
Richard
